I am trying to find the tested proven way to make the TCC lockup with a 4l80 swap from a 4l70. I am running a TBSS E40 ecm and T42 TCM and have changed all the needed parameters in HPT like gear ratio, 3-2 solenoid disable etc...I am trying to figure out if you just use the soleniod control from the 4l60 to lock the TCC. I have heard the term fake relay to keep a code from popping up. Do you need to put a resistor on the TCC PWM output to hot to make the trans happy? I have also seen people use a relay powered by the PwM signal to make it a discrete signal. Anyone running it that can help out. I have the car on stands and would like to do this conversion wiring one time.
Jeff
