What table do i adjust to get more hiss from my 2018 L5p? It has none at the moment and the rumble drone drives me nuts. Been straight piped.
I haven't done an L5P but should be your vane table at idle, close em up. My LMM sits at 80% closed at idle. Run it up to 95% or more and she'll whistle pretty good with that pipe
Vane position down at idle set it to 90% or more.
Try to blend the vane position from idle up and over if not the vane position with be erratic when you press the pedal down.
You want it to be closed at idle and then slowly open when you press the pedal/build boost.
Thank you
