Base Tune for LS7 440CI with the 12200411 ECM
Does anyone have a good base tune to start me off with the LS7 I am building
I will list the motor, If I need to add more info let me know, any help is appreciated,
440 cubic inch
LS7 block 10.8 to 1
bore is 4.135
Heads are 66cc
Lunati 4.1 crank
cam is .584.584 - @.050 Duration 227/223 add-277/283 lobe cnt-113/109
with a 1.8 ratio rocker lift is .618/618
FAST 65.5 lbs short ev6 injectors
factory intake
102MM throttle body
Stand Alone Harness in a Sand Car
No Vss, manual trans
sensors are
Front Cam sensor
24X system with the 411 ECM
ls3 credit card style maff
LS1 single wire knock sensors
LS1 Map Sensor 1999-2001
LS1 1999 O2 Sensors only using the up stream
