2 Attachment(s)
GPI VVT SS2 BARO Tables
I have the base Variable Valve Timing table from GPI but the actual table is to blurry to read.
https://w6q4b2d9.rocketcdn.me/wp-con...ttings-L99.pdf
The instructions say to 0 out the table up to 5200RPM then start at 1 degree and "stair step" up to 6800 I am wondering if it is saying I should interoperate the remaining table? Like in my attachment?
It also mentions to Raise the High RMP Disable and Re-Enable RPMs so I assume i need to set those to 8K
Attachment 106572
1 Attachment(s)
Hello,
This is the picture of How Baro should be setup. This picture was share by GPI team.
Regards.
Attachment 106875
About the rpm it doesn?t say to raise to 8000 rpm. I says 7200 rpm and 7400 rpm. Be careful
