question about G8 ecm e38 2nd gen
Since there are a lot of knowledgeable members here, I'll ask.
Is the 2008 G8gt ECM and 2009.5 G8gt the same part#?
reason asking is because tired of the 63lb/h flow limit- complicates things with double half-half - want the 127 limit
If they are the same - can I factory program ecm,tcm to a 2009.5 vin and then with my existing HP licence to these modules change vin back in them?
If ECM are not the same part.... will the 2009.5 ecm work on a 2008 (when programmed with a 2009.5 software Dealer OEM programing)
and if yes, will (buying a hp licence) can I change the false 2009.5 vin back to my original vin. and tune- I realize i will also update the TCM software- but I believe the TCM are the same part
I have access to OEM programing etc- so OEM programming, setup is really not an issue.
