Trying to set up EQ Error histo with a wideband that doesn't output EQ, please help
Hello everyone. I'm having a bit of an issue.
I'm trying to dial in my VE tables a bit more, but am running E85. So I can't just strait up use my wideband AFR output for tuning the tables.
I'd like to use the EQ ratio error histogram, but I'm having trouble setting things up.
I'm using a Dynojet Wideband Commander, that uses a Bosch 17205 sensor. I'm datalogging off the 0-5v wire between the control box and gauge.
There isn't currently a transform that uses my brand of wideband and outputs EQ.
Is there an easy way to set this up?
If not, I've got some guessing numbers.
My gauge on my wideband goes from0-5v, 10-18:1 AFR
My wideband transform is volts/.625 + 10. Is there a way to use this to make my own EQ transform?
Or should I tap off a signal wire from the sensor to the control box, and would that mess with the output splitting the signal?
Thanks in advance for any help I get :)
