Can HP tuners disable PATS and other modules? I?m wanting to swap a 6.7 and 6R140 into another vehicle, but I know I?ll run into issues with PATS and other canbus issues. Short of a motec standalone, can I flash these out with HP Tuners?
might yea but you might have to use either forscan or ids to disable other modules.
Are you swapping it into another 6.7 truck?
No, totally different platform
Done a 2013 F550 drivetrain swap into a 79 F600...using ForScan only...kept all the Emissions in place...Calif CARB legal swap
Figured out the process doing an Excursion/Raptor Drivetrain Swap.... then it became rinse and repeat on any FORD
We just reference Ford's PC/ED Manual's and work the Faults Codes Module by Module.
Short version: having access to FJDSS is/was helpful ...but with Forscan Hack what you can and build "simulator plugs" where you cant...
https://www.motorcraftservice.com/Purchase/ViewProduct
Sometimes in the BCM in particular depending on how much logic/ controls your bringing to the host vehicle it's almost always easier to reflash and regress to XL trim parameters...
Ended up emailing the stock read to the tuner. Mine is a 2006
