im tunning an 05 hemi and im wondering what tables add or subtract spark? so i dont run into any surprises when i start making boost
Wot spark and PT spark are the main two. There most likely will be limits and temp compensation as well.
as spoolboy said WOT and PT spark are what you will get in those modes. to add to this The only way for them to change would be spark knock,cold and hot deadband as well as a few others i cant think of.. I also make all my spark tables them same except for PT, this way it wont change if you get to lockpin or any other variable.
If you hit a limit changing WOT you will need to modify MBT spark...usually not a problem on a mostly stock setup.
https://forum.hptuners.com/showthrea...l=1#post440552
If you need more info on tuning here is a collection of some useful posts.
https://forum.hptuners.com/showthrea...l=1#post525502
