Do not zero out the injector temp table. That has nothing to do with injector timing anyway.
If you want to learn you can watch this, and also use the EOIT tool in my sig line.
https://youtu.be/Td6oC9CIUas?si=SNGnXReIVRpaQ31n
The other common problem that happens after a cam is a slight surging related to the normal rich/lean oscillations by the ECM. I made this video to deal with that:
https://youtu.be/5hjzI8wSItk?si=RIPvNBTiJB2XlD2F
Both of these are more advanced topics, so it may be better for you to have a professional tune it.
