Does anyone have a scanner log of a 5.3l with throttle position going 70MPH?
I am curious to see some what your throttle position is.
Thanks!
Thanks!
That info would be entirely useless unless you are tuning the exact same vehicle again....throttle position at 70mph is entirely dependant upon temp, weight, road slope, etc.....
i understand and it dosent need to be "perfect"
it seems like i have to push the pedal down a little far to go 70. it that just me or could it be the PCM?
perhaps its really hot out and you got the a/c on, or you have some gears...???:doh:
or a stall....:hi:Quote:
Originally Posted by gman4dx266
what do you mean when you say or you have some gears? what does it do?Quote:
that you have different rear gears than stockQuote:
Originally Posted by wreedz71
OK i do so what?? please explain why you said that.
if you have a higher numerical gear the drive shaft will have to turn more times for the same amount of tire rotation, resulting in a higher engine rpm. you would more than likely know if it had gears in it
DUDE i am trying to tell you i do have 4.10 gears from 3.42. what would this do to having to push the throttle down more????
where did you say that?Quote:
your throttle position will be different than everyone elses unless they have the exact same set up, as well as the same conditions including density altitude
nevermind dude. if there is someone who know what i am talking about please reply.
lol:doh:
