Gen V 2009 JKUR Swap Issue 2017 L83/6L80
I recently swapped an 2017 L83/6L80 (both out of same vehicle) into a Jeep 2009 JKUR.
L83 is 3 wire HPS . I have an LT1 intake and TB installed
I used a Motech Swap Kit with their Harness, ECU, and tune.
Engine runs good in park However when I try and shift it out of park it revs immediately to WOT on its own and does not engage gears.
Here is the ECU and TCM info. I checked on TIS2web and the TCM OS system seems to be correct for the VIN.
Trying to determine where to go next with this. Reprogram TCM, More Tuning, Wiring Pin out issue, Etc as this is going to get very expensive very quickly.
Any help would be greatly appreciated
ECM: 7E8, CAN, ECM -EngineControl - E92A, GM SIDI 2017+
VIN: 1GNSCBKC5HR276823 - 2017 Chevrolet Tahoe LT, 5.3 L, 8 Cyl
Serial: 1121012334523J1J
Programmed State: Fully Programmed
OS: 12691210
Calibration IDs: 12691210, 12680060, 12686081, 12667480, 12667659, 12667718, 12667763, 12680092
Calibration VNs: 000098C5, 0000FC14, 00000C88, 0000F46E, 000000D4, 0000239B, 000074F7, 000068B
None: 7EA, CAN, TCM -TransmisCtrl - T43, GM A6
Serial: DV6637Q529403420
OS: 24276638
Calibration IDs: 24276638, 24290043, 24290037, 24290044
Calibration VNs: 0000E54E, 0000CC5A, 0000D9E8, 0000B
Thanks in advanced for any help.
JR Rager
2 Attachment(s)
Here is my Log file and Tune
Quote:
Originally Posted by
jrager
OS: 12691210
OS: 24276638
JR Rager
Attachment 116904Attachment 116905
