Why does MPH effect shift RPM if it is supposed to hit one and then the other?
I have had this issue on two cars now..... From how it was explained to me by a tuner, the computer will look at both the MPH and RPM tables for a shift. It needs to meet both to make the shift. So, my question is this.... IF the MPH was ~10 mph below what it would actually be at the given shift RPM, why would the car shift before the 6300 commanded RPM???
Basically the car is shifting off of the MPH and not the RPM.
Does it actually look at one then the other or do they need to be with in a certain window????
I had this issue on a stock trans 06 gto and it appears to have gone away now that I bumped the mph up closer to actual. It is doing it on my 00 z28 with FLT Level 4 tranny now. I just completed this car and am working out the shift points and stuff now.
Just trying to understand how/why it is doing what it is. The tuner said that it may be something in the computer protecting the trans, but all the tq mgmt should be disabled from what I can see.
I want it to shift off of ONLY the commanded RPM, so I just need to figure out what needs to be done to accomplish this.
Thank you!!!!
