Originally Posted by
TCSS07
yeah seems to be something going on with the tb
couple things i noticed in your tune - if your going to run ve only set your dynamic airflow high rpm disable to 8k and re enable to 7900 because your still telling the ecm to use maf above 4k
Disable the p0068 test by setting it to 8k because ive had that test still enabled be a issue with big tb's and causing R.E.P. and you may want to disable the tests for p0101,p0106 and p0121 set min ect to 493 as it will may also cause a R.E.P.
since your still on a 1 bar os and in ve mode your spark will default to the low octane chart so you must copy your high octane over to the low octane to get the proper spark
