2 Attachment(s)
2017 Golf R Requested Torque Limiter?
I was trying to mess with my friend's Golf R, but I'm running into an issue requesting over 280ftlbs. (I'm using a dyno so it's easy to tell if there's an actual difference). I've tried going up on the requested torque with no luck and I can't find any limiters in the file itself. I know these ecu have many layers of limiters, so maybe they just aren't defined yet. I was able to adjust some other things with correct results (PE AFR, Stoich AFR (E30), Etc.). If someone could change what I'm missing or let me know that'd be greatly appreciated. I included both the stock file and a basic adjusted file I was trying to start with. Thank you for the help.
