at what percentage alcohol does it switch to the alcohol pe table? or doesn't it work that way?
:o000
Depends on what you have in the multiplier table and how everything else is setup.
Check the "[ECM] 12636 - PE/COT Spark Advance Correction Mult vs. Fuel Composition" table. Here is how I have mine set up. Basically nothing happens until 10%+ then it interpolates up to the 20% cell.
Attachment 130941
Sorry my bad...that table only effects spark. As far as I know the PE should always be interpolated based on alcohol % (0-100%) between the [ECM] 12400 and [ECM] 12403 tables.
If the tables are the same, then nothing will change with E during PE. Are you specifically seeing something off in your logs?
Has anyone confirmed how the gas vs alcohol PE ratio tables scale... is it just 0-100% multiplier?
HP Tuner peeps, I take it you did not find a correlating multiple table? There still should be some connection between these in the code to determine the scaling.
I'm running a little high on IDC and would love to lean a little with higher E mix, but without confirming the scaling I'm hesitant.
