Bosch 36lbs injectors 0280155868 data
I wish to change the 28lb injectors in my LS1 Gen3 05 VZ Commodore to the 36lb injector (0280155868) but where do I get the data to update the PCM tables:
I think I need at least
[ECM] 12311 - Injector Flow Rate vs. KPA VAC
[ECM] 12315 - Minimum Injector Pulsewidth
[ECM] 12310 - Injector Offset vs. Battery Voltage vs. KPA VAC
[ECM] 12314 - Short Pulse Adder
Also do I need referenced or non-referenced data - not sure what the difference is - can someone explain?
