trying to raise WOT shift points:-
I was looking at your tune and comparing to mine. I am just now starting to play with the transmission. I am happy with the part throttle shifts but needing to raise the WOT rpm shifts. I changed the WOT shift rpm table but has had no affect. I noticed you changed boost and hold pressures, does that affect WOT shift rpm also? Why did you not change 2nd to 3rd that much? Any help would be greatly appreciated as there is little info on the 46re's. Hoping you can save me a lot of time in experimenting as Automatics are not my strength.
I have a 410 stroked 5.9 with forged internals and aluminum heads. Was poking around your engine changes also :-)
