ZFR LNF Cobalt Acting Badly Cannot Figure this One Out.
Here is a screenshot showing the issue. It looks like a misfire or some other fault but none are recorded when this occurs. Plugs are OEM one month old. We tried stock gap and 0.028" gap, tried unplugging the purge valve, cleaning the MAF, Rotating the filter (K&N intake) no change. I tired an older tune revision before this issue popped up and no change seen. This is rare but I think I need help with this one. No codes pending either. Some pulls in this same log the car seems fine no issues. Even with the issue the last log the car ran a 4.0 60-100 time on 93 octane. MAF sensor bad maybe? MAP sensor bad (has 3 bar MAPs tried disabling P0106 just to see if that was the issue but no change) Injection window misfire comes to mind but no misfires recorded so?
http://i43.tinypic.com/1yl5eh.jpg
Same log Pull from 70 ish no issue at all (Ignore the tiny bit of KR never tune version has none seen. What the Heck?
http://i41.tinypic.com/im84kx.png
