Mistakes in file definitions
There are many dumb mistakes in the file definitions in the Mopar files.
For example, any time there is a temperature "span" such as hysteresis or dead-band, if you display it in Fahrenheit it is wrong. Only the NATIVE temperature range is correct, which is often Celsius.
For example, a span of 2 degrees Celsius is about 3.6 degrees Fahrenheit, not 35.6. Although 2 degrees Celsius is equal to 35.6 degrees Fahrenheit.
There are mistakes like this all over the files. If something doesn't make sense, try setting Tools>Options>units to NATIVE.
Anyway, if something doesn't make sense in your file, it's probably wrong. Good luck! You can try getting this fixed if you're patient enough.
I wonder why simple stuff like this has been wrong for several years?
