Are the LT1 MAP Characteristics different than the LS1? My Kpa maxes out at 85 at WOT. Altitude here is 3700'Attachment 107235
Which LT1?
Like mid 90's LT1 or the 2014+ LT1?
And the answer is likely yes for both.
This is a 90's LT1. I searched for a while and couldn't find anything on it.
At your altitude that’s about right
as in, you want to see an LT1 VE table? I have those files, with LT1_Edit. Good stuff.
http://www.bfranker.badz28.com/LT1Edit/LT1files.htm
I kept searching today and found this.
Attachment 107244
This would make MAP Sensor Linear 102kPa and MAP Sensor Offset 15.00kPa
I'll make this change and try it out.
