what setting to make VSS work on 2013 camaro using Front wheel sensor
What setting in teh ECU need to be set so that I can use the Front wheel sensor for the Speedo
we have a car with a Transmission swap, and just want the speedo to work
there is no TCM and there is no VSS on the transmission
we know that the ECU has VSS as pin 71/72
but we cant seem to get anything to make it read
we currently are trying to use the Front wheel speed sensor tied to the VSS pin in the ECU
I think its just a setting in the ECU I need to change, but I dont know which one makes it read the VSS 71/72 pins
