team,
did a remote tune using the mpvi2 and customer noticed that M select is not highlighting in dash and cannot select any gears.
everything else is perfect in Drive (D)
anyone run into this...
regards
team,
regards
Re-enable VID block
i recall we need to disable VID for gear change. yes i did that for 4,56 gears and 34.4 inch tire
vid block enable will fix it.
yes, so anyone that may run into this
VID keep untouch, and you have two sections for tire and axle adjust, make your adjustments and switch to calibrate from learn from BCM and you should be golden!
