Is a ignition only tune possible?
I'm wondering if its possible to tune a ecm/pcm to only run an LS Gen3 24x ignition system. similar to a MSD 6014 controller. i would need an ign map based on RPM. with an initial timing of 12 degrees on a curve to 28degrees at 2500 rpm. or i could use a fixed timing of 28 degrees, but this makes idling and starting a little harder.
if it's possible could you provide the ecm/pcm used and variables that need to be modified/set. wiring the cam/crank/coils is no issue for me. i could just use the MSD harness. But i'm a complete newbie to tuning pcm's. thanks in advance (pun intended)
Dave in NY
