innovate lm2 cant get data off the usb.
I did search but did not find anything. I have a innovate lm2 working fine. I am using a mpvi3. Fresh install of vcm scanner. I am trying to get data off the usb cable into vcm scanner. When I open innovates data logger (logworks) I can connect to the lm2 and see the afr no problems just using the usb cable. So, I do not think it?s the lm2 unit/laptop/cable. Let me explain what I am doing in vcm scanner I click add channel > serial port > Innovate > Innovate sp afr > right click newly added channel > transform > parameters click to install change > oxygen sensor > air fuel ratio > Innovate lm2. Then I hit start scanning. All the stuff coming off the obd2 port is working (rpm and all). Innovate sp afr vanishes. I do not have logworks open at this time I understand I can use the port on two programs.
Question: Is it possible to use vcm scanner to pull the data off the lm2 just using the usb port? If so, am I doing something wrong?
Edit: I know I can use an output off the lm2 and get the prolink+ and wire in a input but hoping I don't have to.
