Need help filling in the blanks for non-GM EV1 injectors
Is there a better way of getting the Flow Rate vs KPa table correct for a set of Bosch 0280155831 injectors from a Volvo XC90?
https://www.injectorplanet.com/produ...-volvo-9186340
So far, I've been comparing injector ratings for various LS1/LS6 Corvettes to their respective tunes. One problem I've noticed is that in the link to the website above the injector ratings don't quite match to this link that I believe to be accurate:
https://www.psiconversion.com/tech/l...more%20rows%20
For example, 12561462 is listed as a 30lb@4 bar; however, injectorplanet lists it as 24.8lb@3bar (=33.1lb@4bar).
Basically, I'm having trouble cross-referencing the values because of the discrepancy. Best I can come up with is to tune the Volvo injectors as if rated 39lb@4bar.
