2 Attachment(s)
L83 Swap Throttle Hang Issues
I'm extremely new to anything GM tuning related. Threads in here have been a huge help to get me this far
Engine is a 2014 L83 with TS heads, CHE trunions, Johnson link-bars, TS Stage 4 cam, SBE, 95mm throttle body, C8 exhaust manifolds, 3" collectors into 3.5" single exhaust (packaging reasons), BTR Trinity intake, 4" intake tube, CD009 manual trans, and flex fuel sensor wired in. Using the E92 truck ECU with Sierra OS 12663390. I know of the issues people have with auto OS's when they don't see any VSS info. I was having the same ones, then I wired in a VR style sensor on pins 6/7. All wheel speed values read 0, which negated all the work I previously did on the tune before I knew about the VSS woes
So now with VSS reading properly, I've gotten it mostly lined out from idle (975ish) to 1700ish rpms when free revving. It's not perfect, and is slow to return to idle when revving slowly to 1700, but it's better than when I started. However anything above 1700rpms hangs, sometimes for 5 seconds or more, when returning to idle. 1700 and below doesn't hang but does return slower than I expected. Also when WOT free revving it doesn't seem to go over 4k. Haven't figured that part out yet either. I've read through as many forum posts as I could find of people having a similar issues, but many of them are old dead threads now with no updates or fix. Tune and latest log posted for advice
The MAF isn't properly scaled above 5100hz so that can be disregarded. The MPVI2.2 wideband in the log can also be disregarded: The sensor is bad
