6 Attachment(s)
14 Mustang Copperhead Flex Fuel Not Working
Hi there, tuning this '14 Mustang and customer requested a flexfuel tune. It has 47lb injectors and a Boss intake mani and JLT cold air, stock apart from that.
Got it all tuned up on pumpgas, then populated my flex tables and flashed the car BEFORE filling it with E85. Filled the car up, fired it up, ran good. Made a couple dyno pulls and fueling was good however the car made no extra power and was actually running less timing and showing some knock retard??? I didn't supply the """E85""" but I'm thinking I got bamboozled here, throwing 10 gallons of E85 into a nearly empty car and there's no way it should be pulling timing after.
The only reason I am thinking it could be tune related is due to the fact I can't pull up an ethanol or alcohol percentage in the VCM scanner, the parameter just isn't there. Could it be that this OS doesn't support flex even if it's turned on? This is a Canadian car. Going into it with Forscan it shows the inferred flex value at 9.8% and not moving.
Attachment 134464
Attachment 134465
Attachment 134466
I am including the tune file in case anyone see anything jump out at them in there, and a datalog with a full tank of E85 and (for example) running 21.5* at 5000rpm with 2 degrees of knock retard.
Attachment 134467
Attachment 134469
