Anyone has a 2018 Mustang GT (A10 prefered) supercharger tune - anything ProCharger, Paxton, Whippe, KB, Roush etc
Lots of new tables - want to see what all they change (vs 11-17).
Thanks!
Thanks!
Anyone?
Posted by caged in another thread
Weird. I currently have the MPVI tuner and 4.0 suite version but when I try to open that file it says MPVI2 required? The car I'm working on is a 2018, and I can open it with not problem. This sucks.
Roger
All 2018 Aftermarket/Ford Racing Cals require a mpvi2 in order to open in the editor (Each time you open it).
You also need the latest beta and firmware to open that file. 2.0.107 is the current fw and 4.1.372.0 is latest beta.
Not sure this file will help you as roush has its own custom os and run map sensor for full speed density with no afm.
So does any one have anything else? Especially centrifugal.
Or any tuners out there that I can pay for a base tune?
Thanks.
PM sent.
Hi, im novice to this whole tuning thing but wanted to give it a go. However i quickly learned there aren't many references to consult in an attempt to build this skill. I was hoping someone could offer me some guidance in that regard. With that being said does anyone have any supercharged gen3 coyote tune files I could maybe take a look at so I can compare them to my stock tune file? Right now im working on trying to get this 2020 gt500 predator supercharger to run on my 2020 Mustang Gt. Also any advice/feedback would be greatly appreciated. So far i've only attempted to update injector data. The car turns over and quickly kills. Everything on the car is mostly stock. Really need some help. Thanks
Here's whats on the car.
2020 Mustang GT500 Predator Supercharger
2020 Mustang GT500 Fuel Rails
Deatschwerks 95lb(1000cc) Injectors
VMP Fuel Pump Voltage Booster
Stock Fuel System
Stock Throttle Body coupled with Airaid CAI
probably the injector data you input is not correct
thats what it was i was looking at the wrong injector data i put the right one in and it instantly started running better. but now its throwing the wrench when i get it up to 50mph. cant seem to figure out what the issue is.
