It's the Brain Worms.
This is a real vehicle service history...
10 JAN 2008 CUST STATES BRAKE LIGHTS INOP
TECH#3 - REPLACE BLOWN FUSE, UNABLE TO DUPLICATE
- 0.2HR REPLACE FUSE
22 JAN 2008 CUST STATES BRAKE LIGHTS INOP
15 FEB 2008 CUST STATES BRAKE LIGHTS INOP
27 FEB 2008 CUST STATES BRAKE LIGHTS INOP
11 MAR 2008 CUST STATES BRAKE LIGHTS INOP
13 MAR 2008 CUST STATES BRAKE LIGHTS INOP
09 APR 2008 CUST STATES BRAKE LIGHTS INOP
TECH#14 - FOUND BLOWN FUSE, FAULT NOT PRESENT AT THIS TIME. INSPECT WIRING AT TRUNK HINGE AREA, NO PROBLEM FOUND. TRACE HARNESS - REMOVE REAR SEAT CUSHION, C-PILLAR TRIM/SILL PLATE FOR ACCESS. FOUND WIRE SHORTED TO GROUND UNDER LEFT REAR DOOR SILL PLATE - FACTORY ASSEMBLY ERROR, HARNESS MISROUTED. CUT AND SPLICE DAMAGED WIRE, TAPE AND RE-ROUTE HARNESS TO CORRECT LOCATION, REASSEMBLE. REPLACE FUSE, TEST OPERATION OF ALL REAR LIGHTS, ALL OK.
- 0.2HR REPAIR WIRE AND/OR CONNECTOR
Attachment 121375
