H/C LQ4 Tuning
Current Mods:
6.0L LQ4
L92 heads
EPS 222/226 .597/.598 112LSA +4
3.73 gears
Yank 3000 Stall
Problem:
Trying to get this tune right (at least AFR), and I can't get my AFR Error Histogram to work. I used 5_Liter_Eater's guide for setting it up, but I can't seem to get it figured out.
Also, I'm using an AEM wideband right now, and my STFT seem to be swinging the opposite of what my WB is reading. Am I doing something wrong here, or going crazy? Log attached with Tune and Cfg.
goto the help files and set up a SD tune for logging your VE AFR error
I finally got that figured out through a post on LS1tech. The problem I'm having now is that at idle I'm seeing around 13.2 when I start the car, even when it warms up. I also seem to get good bit of hesitation when I go WOT in 1st gear. It tends to happen in 1st and 2nd, and I'm almost positive it's not a trans issue. right now I'm just trying to get my VE straight. Any help looking over it would be greatly appreciated.
keep working on the VE till you are getting the AFR you command. Do your tuning on a hot car
my tune is in here...few pages in if you wanted to compair, I started a thread about track tuning...
