converting pixels to time
Is there a certain time associated with each pixel in the chart display? I think it would be cool to be able to get 0-60 times, shifting times, etc off the chart. I tried using a stopwatch and it looks like about 100 pixels per second. Is that anywhere close? Thanks.
Re: converting pixels to time
Well, it all depends on how many PID's you are logging.
The chart views 200 frames.
If you are logging 13+ frames its 10fps
If you are logging 7-12 its 20 frames per second
1-6 is 40 frames per second
So, for your standard chart using the default config the chart shows 20 seconds of data.
We will have timestamps in the future to make this much much easier. :)
