C7 Stingray, Ported Z06 SC, 103mm katec TB, LTH, X-Pipe, Catless, VVE or VT Startup
For this setup, what makes more sense to increase first to get it to idle? I started last night with increasing the VT and VVE by 10% each, then flashing and attempting to start. The second time I did that it just started to idle, so I feel like I was on the right track.
Also, the TB only shows a range of 18-30% when I move the pedal. Where do I adjust the range for a bigger TB? Just not seeing any voltage tables or anything like that for them.
Also, should I change the sensor setup as far as the SC/TCn section to SC-TIAP-MAP or just leave it stock. I have usually left them stock, but this is the first conversion I have done like this.
