Enabling Alternator Charging - L83 Swap on Hotrod
Hi folks,
I'm trying to enable alternator charging on what is essentially a hotrod with an L83 swap from a 2017 Silverado. Alternator is currently not charging at all. To my knowledge, vehicle doesn't have the BCM nor CCM (only PCM and TCM) and the alternator wiring has been simplified (I don't have exact details yet on the wiring but I can confirm later). Are there any particular alternator charging settings that can be done in the PCM to try to enable alternator charging full power, full time?
PS: Confirmed from the shop that did the swap, there is no BCM and the two pins of the alternator plug are wired factory to PCM, but the PCM is still looking for the amp meter on ground (amp meter has been removed) to calculate power draw and regulate voltage, so I'm looking for a way to force the alternator to run all the time with full power without the use of this amp meter.
