Hellcat with Magnuson 2650 idle hangs after hard acceleration
Working on a Hellcat with a Magnuson 2650
Previously had a modified stock blower and drove around with a vacuum leak for about a year, (a few hundred miles, vehicle is rarely driven). So while it was apart the owner wanted to switch blowers.
Manual Trans
93 oct (100 oct after issues are sorted)
Magnuson 2650 with the smallest of the 3 available pulleys installed
Stock TB
Stock Intake
Stock Pumps
ID1000's
American Racing Longtube Headers
Just started tuning the new setup and have two issues:
1. The vehicle wants to run severely negative timing (-64 degrees) on cold start so I set the minimum timing in the spark section to -5 degrees on cold start to try and remedy this. Is there a better fix for this?
2. The idle hangs up around 3000rpm after any hard acceleration. I'm not sure what to modify to remedy this.
The cal file and a log are attached.
If anyone has any ideas or has ran into this before let me know!
Thanks!
Attachment 78523
Attachment 78524
