Audi RS5 2015 - med17.1.1
Hello, I'm trying to tune my Audi RS5 2015 with med17.1.1 ECU to Pops & Bangs tune, but everything in this ECU in VCM Editor looks different than those I've seen in some tutorials.
I have modified Spark - Advance - Base Var 0, 1, 2, 3 to 10% engine load value 0 for 3500rpm and up.
Also minimum spark for drivability spark for 0 and 10% engine load.
I can't find any fuel cutoff map or anything else that can be changed in that manner.
Any help would be greatly appreciated as I just spent quite a lot of money to get MPVI3 and 6 credits just because of my RS5 tune.
Thank you
should be a fairly easy tune
Quote:
Originally Posted by
1mteddy
do you have a cat ? ill look over your file in just a second.
1 Attachment(s)
pops and bangs for you to play with
needs to be negative in the areas where you have 0 for timing . for that engine i would start at -1 no more than 7 should do what your looking for , you can go more but youll have a shit ton of heat to deal with.Attachment 131947 lmk how it goes. a video would be nice.:hi::worship:
the day my manifold turned into an LED
