wondering what the best way to frim shifts and add durability to trans. dont have any exp tuning 6l's thanks
here is the file i pulled compared to others seems way different is this because its a 2500?
Im having trouble with my 6l90 any ideas on tuning
Best way to firm up shifts is decrease shift times. Much more positive feel without the harshness you get when altering inertia profiles (my experience). Increase line pressures as well a bit at a time though. Also under tcc slip ac with off drop those to 0. Go to transmission torque management tab and alter shift torque factor by 20%, shift torque factor will pull timing during shifts and dropping it x% will limit how much timing is being pulled. Under torque management-> torque reduction -> downshift -> set to disable, speed control terminate -> change to immediate. try those and see if its what ya like.
