1 Attachment(s)
ls3 turbo 600whp with 6l80 with trans issue...help needed..
Hello, I resently bought a used and bulit 6l80, it also included a "2500rpm" stall converter.
It was bulit sometime ago... 2010 it says.
It was built with best the parts that was avalible back then and they even bougt a tune for it from "someone" in US.
Back then it worked just fine on a c6 procharger with about the same or even more hp. think they ran high 9 on 1/4mile.
My problem now is as followed:
when going low/part trottle it sometimes (but not always) slips when going 2-3rd, the more I acc the better it gets.
So I dont think/hope it the tran itself.
I`ve tried some diffrent settings with bluecat trans calc, but the problem only changes to the 3-4th gear.
If I go full trottle it works much better.
Big problem is that I can`t fint anyone back here in sweden who knows this trans:-(
Oil level is correct, can trying overfilling it with a quater help this problem?
I guess it would be god to make a log in the scanner, but not sure what exactly to log? please ca someone explain how to, newbe with hpt and the scanner.
Any ideas are welcome. A big race coming up in a couple of weeks, it`s almost like dragweek but it`s called streetweek here.
[email protected]
You can also have a look at my CamaRRo at facebook #RRacingsweden if you like, it`s a all true "home made" car with fiberglass body on a tubechassie, ls3 e85 turbo.
Thanx in advance:-)
