I posted this at 3800pro and then I thought I could get some good insight from you guys also.
Help w/LC-1 install
Okay guys, I've read the posts here and the install manual. My question is where are you routing the wires into the cab? And if some of the wires go to ground, wouldn't those stay in the engine bay and not go into cab? But the wires are bundled into a cable assembly, so if someone could give a detailed write-up of install, that would be very much appreciated. TIA - Jody
