'15 3.5L F150 Unable to disable traction control
Hey guys. I'm having an issue with my '15 that I can't seem to get around. It's almost like I'm needing access to a function that isn't available. I've tried about everything I can think of here.....with no luck.
The issue is, even though the traction control is turned off in the cluster, as well as pressing and holding the button to disable advance trac, I'm still getting a traction control intervention on a hard wheel spin event. As you can see in this video, it kills the power entirely once the wheel spin takes off really heavy:
https://www.youtube.com/watch?v=vWDr-UUKoik
Looking at the log, you can even see that the TCS is the torque source, and also you can see the accelerator pedal is still wide open, but the throttle blade is shut down due to the TCS request of less torque:
http://i1352.photobucket.com/albums/...psigdslvvl.jpg
Anyone else run into this? I've tried setting all fuel cut and spark only torque ratio's to 1/0 respectively, with no luck. Setting traction control air mass to 0 and 100%, nothing. It's almost like, I am missing a traction control air mass value or commanded torque value that can't be seen in the tune.
Open to suggestions!
