1 Attachment(s)
fuel trims not adjusting properly 6.4 hellcat supercharged
Hey guys so doing part throttle and drivability tuning on my Scat pack and when changing the ve tables I am not seeing my changes reflecting in the tune at all same trims with each log even after adjustment. Car is a 2020 Scat pack running hellcat supercharger and injectors. It was pulling 15% at idle made the ve corrections and still pulling 15% has anyone seen anything like that? Best part is the wide band shows I am right at 14.3-13.5 at idle so its not as far off as the log shows. Mechanically its perfect, brand new injectors, plugs look absolutely perfect too. Could I be chasing my tail trying to get closer to 14.5 steady at idle? I attached my current file. Idle surges 50-75 rpm too so I was hoping getting the trims cleaned up could smooth that out a bit. I'm pulling my hair out at this point too because I have spent like 2 days on these trims.
Hello, I need a file for the Charger and Eddie I want to skatback 2020 in stock
