2 Attachment(s)
2016 L83 w/LT4 pump erratic fuel pressure
Myself and my buddy (tuner) have been dealing with and torubleshooting an erratic low side fuel pressure issue. I attached both and idle log and the current tune to see if anyone has some input on this matter. Let me lay out some details about the truck as it may all be tune related, I just don't know at this point.
2016 Silverado with L83 6L80E combo
76mm Turbo setup
32% Cam lobe camshaft
DOD delete
LT4 HPFP
LT4 fuel injectors
-6 PTFE Hose with AN fitting directly into the HPFP
E85 sensor
DSX Aux fuel system
LT2 Intake
LT5 Throttle body
3200 Stall
What I have done to troubleshoot thus far.
Installed new low pressure sensor-no change
Totally disabled the DSX and capped the T fitting- no change
Installed OEM in tank pump-no change
Installed OEM Fuel pump control module-no change
Installed OEM LT4 feed line/check valve prior to HPFP-no change
The initial thought was the LT4 high pressure pump was not set up correctly in the tune-
The lack of factory check valve prior to HPFP could have allowed pulsing back into the feed line
The large fuel lobe cam could be giving a jack hammer effect on the fuel line giving erratic pressure
I went ahead and installed the factory check valve hose (GM 12642289) and no change
Not sure what could be causing this??? My buddy who is helping me tune says its a real issue and we need solid low side pressure to tune properly. I have another tuner telling me its not a huge deal as long as we are not having high side issues, the desired VS provided high side seems fine. we have not seen any indication that the combo of intank L83 pump and DSX aux pump cant keep up with the highside desired pressure. Attachment 118028Attachment 118029
