1 Attachment(s)
Need diagnosis help MAP P0108
Lately my truck has been throwing a P0108 code, CEL and going into a limp mode. It only happens on the highway usually above 65mph...which is awesome when the motor goes to idle and makes no power. Turning it off and back on doesn't help, only pulling the power for 10 seconds will reset it and it will run fine until the next random occurrence. Today I was logging when the problem happened, you can see it drop like a rock at 11:44. I replaced the MAP sensor, I have 5.0v at the sensor. I'm using a PSI harness and I don't see any breaks in the wiring loom. At this point I'm thinking bad PCM?? Would appreciate any help!!
