Help needed with the WB2
Hi
I have purchased an HP Tuners VCM Suite PRO, and also i have ordered the Dynojet Wide Band 2 Sensor and Controller, the thing is i got confused and i don't know what to do.
I thought its was a potable WB2 but i discover that its not, i have to install it directly from the car to the exhaust underneath the car.
So my Question is how can i use this with the MPVI Pro and connect it with it? did i made a mistake ordering this one or should i have look for another portable one that i can just put the WB2 at the rare end of the exhaust pipe of the car.
i just wanted to make portable so i can use it on different type of cars
Thank you.
I to have made this mistake. i will recieve my hp tuner and dynojet this week. What are peoples thoughts?
You dont want one at tail pipe you want to install in a bung in the pipe.
Innovate sells pipe extensions so you can clamp it to the tail pipe.
http://www.innovatemotorsports.com/x...cat=271&page=1
I don't like extensions, I always weld O2 bungs and the readings are always good
OK but how to connect it and make it read by the HP Tuner MPVI PRO?? This i was trying to figure it out..
my thought is u get bad reading from clamping it at the tailpipe due to its to exposed to the air outside... that's my thought but please correct me if i'm wrong
