Can anyone else confirm that the TPS reading goes to 0% when cruise is enabled, latest version HPT, scanner. Is there a specific channel I need to add to see TPS when cruise is set..
Normal, the ecm uses a table called equivalent throttle when in cruise control.
How can I see that in real-time when connected? I do not see a channel for it.
If there is no channel for it then you can?t see it in real time
Yes tps goes to 0...why you wand to see that??
Without knowing the position of throttle in % you do not know when the shift tables for transmission are taking place. Output shaft rpm vs tps % determines shift and lockup.
Yes and that's where I have an issue Im attempting to resolve. When cruise is enabled and you go over a hill the throttle backs off and the truck starts jerking, its either attempting to down shift or lock/unlock the torque converter, the later I believe is the culprit.
You can apply just a little bit of pedal/accelerator and the jerking stops. So that tells me the throttle position effects the issue. If I could see this position while in cruise I could just copy the reading to the cruise table and Im pretty sure the issue is resolved.
Sounds a lot more like the cruise control settings not reacting well with your engine tuning than anything else
That is true, the engine and trans is running factory tune. I do not want to make any changes until I can see throttle position while in cruise.
Probably one of these below pictured tables, my guess is the one on the right.
Attachment 123964
That pic isnt relevant to what is viewed within HPT when adding a channel for view/logging, that pic would be reflecting shaft speed and % if using editor. Keep in mind I'm attempting to view/read tps when in cruise.
If one of those tables is the table used for the throttle when on cruise control than it is 100% relative. Throttle position is not based on shaft speed. It is based counts/voltage.
IF is a very large word and you have yet to name a table. (HPT has many tables, 1000s) No one said throttle position is based on shaft speed but you. Shaft speed compared to tps determines shift and lockup.
Hmmm... looks to me like YOU are the one saying that that picture would be reflecting SHAFT SPEED and %. I know how to goddamn read and I'm not retarded and no HPT does NOT have 1000's of tables mapped out for your specific calibration. There is a mix of almost 20,000 scalars, bits, and tables in your calibration and HPT has maybe 3% of that shown in their software. I can see 100% of what is in there. I told you that while in cruise control the ECM uses what is called equivalent throttle for determining throttle position. It uses equivalent throttle position because you are NOT using the damn throttle and it needs something to be based off of under driving conditions to regulate engine speed. There is equivalent throttle scalars in the calibration but no throttle table clearly labeled as equivalent throttle. In that picture the table on the left is the remote throttle which I believe is part of a different feature with the calibration, I can't recall what the other table was labeled as but I am pretty certain that is the equivalent throttle table. The damn table used while in CRUISE CONTROL. Something that you are wanting to see in datalogging, something I read you asking about and wanting to see further up on this thread which has already been stated it isn't something that's been mapped out for the HPT software. Shifts and lockup on the 48RE are based on throttle position and output shaft speed, if you are in cruise control and not touching the throttle, well, its gotta have a damn input to feed throttle position from somewhere! And that is where the equivalent throttle comes in and if it is the table on the right in that picture... well it makes it pretty goddamn relative! Just doesn't provide you any use because you can't see it or log any feedback on it. HPT has the shift tables pretty clearly labeled for which ones are 3-4, 4-3 shift while in cruise and which ones are for 3rd gear and 4th gear lockup/unlock while in cruise, it practically slaps me in the face it stands out so well, so what's the problem with just adjusting them till it sits where you want it to???
Hfswada
prob needs a new trans if it's on stock power, we all know they are junk from day one unless built
