B1S2 for Fuel Pressure - '97 GTP
If I purchased a psi sensor from Innovate (http://www.innovatemotorsports.com/x...at=265&page=1), could I hook this up to B1S'2' and then read/monitor with HPTuners?
I'd guess the sensor would work because it's 0-5 volts that can be a custom PID in HPTuners but I'm not sure if B1S2 is capable of that. I'd have to get switched 12 volt to the sensor is about it. I'm not sure because I have a "dummy" plugged into B1S2 because I removed the Cat (before I had HPTuners).
Thanks for the help and advice. I would like to also add a LM-1 via the EGR.
-Scott
