4 Attachment(s)
Supercharged LS3 erratic commanded EQ\AFR
Hey guys, having a bit of a troublesome one here. My commanded AFR is going all over the place during WOT. Have tried a bunch of different things in the tunes but nothing is consistent. the commanded EQ will jump anywhere from 11.2 to 14.7 depending on its mood. When I do get a complete pull seems as the car stays in O\L tables as it commands 11.3 and trims try to pull a bunch of fuel. I can make a pull and everything be ok, make adjustments to the tune but no adjustments to WOT fueling and next tune it'll command 14.7 at WOT. I'm hoping im missing something stupid but never had this issue before. Car makes good power when it cooperates(690ish) please see attached logs and tunes; log "Run8" corresponds with tune 5 and log "what2" goes with tune 7. No major changes were done between these two tunes. Just tried to clean it up a bit. Run 8 commanded 11.3 entire pull, What2 initially commanded 12.5 then jumped to 14.7. Any help would be greatly appreciated. Thanks!
P.S. Im aware of the fuel pressure lol, dont feel its a contributing factor though. High PW yes, commanded AFR no
