Anyone have a man trans file so I can segment swap this auto to man conversion. Thank you!
How about a year make and model. I doubt there are very many people that have every OS number memorized.
2004 Silverado 5.3
have you checked all the 4.8 files in the repository?
Yes
Searched through my library. Don't see a single manual trans with that OS.
You're going to have to use a different OS.
In a pinch you can just disable all the auto trans stuff and tune away. You won't have reverse lockout but people have wired that to the brake switch.
Pretty sure I have a Silverado of that year with a manual. It will need factory programming with SPS/Techline Connect. If you don't have anyone in your areas you could send your module to me and I can factory program it and put your tune on it.
What I did is looked at approx 20 stock tunes of different variations and years that have that OS. All of them I ran through TIS. This was the only update I could find. You are correct. I do not have his VIN and I can not say with 100% certainty on other potential updates etc.
1GCEK19V54E119868
Thanks for the help!
If you go to this site https://tis2web.service.opel.com/tis2web/ and enter your VIN and look at the complete history for your vehicle the PCM should have been updated at some time after production and contain all the following segments. If your main OS is still 12585950 then for whatever reason it never got the updated calibration from GM. These are all the correct segments it should have. Once it is updated there will be calibrations available with same OS to do the segment swap.
12587603
12587682
12587940
12602137
12578787
12578797
12585937
12578993
