2 Attachment(s)
Chevy Aveo T250 ECU pinout
Hi! So, I was studying the pinout of my ECM, and it looks something like this:
Attachment 141130
Attachment 141131
As you can see, there are two similar set of pins. One set controls ignition for coils 2 and 3 and the other for coils 1 and 4.
I have a single coil system, so I assume those pins control the spark plugs directly by sending a signal to the coil.
My question is, why are there two sets of pins that control the same instead of 4 pins (one for each spark plug)?
Are two spark plugs firing at the same time? Do those pins only control timing, and the firing is directed by a different circuit?
Thanks in advance for any help you can provide.
