can someone look at my tables see if anything could be wrong.
i dont feel my trans shift from 2-3, i think they might be set too high.
its a 99 trans am a4
Post your .hpt file, as there is a lot more to trans tuning. What wot shift rpm did you want?
Russ Kemp
wot seems to be ok, its normal driving i have trouble with.
thanks
anybody...:pray:
what gears are you running? I have a 99 also with 3.73's and 4000 stall and the way mine's set up is pretty good on the street if that'll help.I think from your tune you have your running 3.23's correct?
yup 3.23 gears. and a vig. 3200 stallQuote:
Originally Posted by firebird380hp
Attachment 5877
thats the tune I have in mine and it works well for me........but as you already know it's at your own risk lol.........
Try this trans tune. Why is your commanded PE at 14.49? Good thing your open loop table is 1.13 (12.94 AFR), or you would be very lean.Quote:
Originally Posted by blownta
I'll Post the tune tonight after work.
Russ Kemp
acctually it is running lean, my wot is, my idle, cruise.
this is according to my aem wideband, car is going on a dyno for a tune soon.
if you notice anything else wierd please let me know.
thanks
Here you go.
Russ Kemp
thank you sir.Quote:
Originally Posted by Russ K
