Exceeding Spark Airmass in tune
First off, I'm assuming the cylinder Airmass channel in the scan = spark airmass in the tune.
The only place I see in the tune that uses spark airmass is the spark table which I have scaled to max out at 1.52 g/s but I'm seeing 1.70+ in the scanner.
I don't want to adjust spark beyond 1.52 and assume it will just maintain spark at the 1.52 setting but do other parts of the tune need to see it scaled higher?
In other words, should I scale the vertical axis for the spark tables to 1.80?
